Old 07-01-2007, 10:53
mr2sc89 mr2sc89 is offline
mr2sc89 is an unknown quantity at this point
yep that sounds like my car. has a hybrd turbo. an custon exhaust. na i hought it off some guy in milton keyns. i didnt even know about this site until i googled it! and i found my saviours. the guy i bought it off couldnt get it started either, he must have bought it off max power. he brought it to a garrage, they replaced ecus, everythin. i posted up my problems here, and got loads of helpfull replys. im a mechanic so i ran through everything, and i mean everything, so i got fed up with it one night, i loged on and went trough every post again, and i noticed i think norterner said to check the block connectors under the air box, as these were giving him similar problems in the past, it didnt look that bad, but i had tryd everything else, so i cut and rejoind every wire sepratly with seald connections, and first turn of the key nothing, and i look at the engin bay and kicked myself as i had left the plug on the first cylinder out. he he
so i tryd her again. and up she went. first go. i did backflips. awsome feeling. so now im prepairing her for prodrift series. ful custom cage, new bride stering wheel as it had a horrible star trek one. have an omex ecu to go in, also have a t3 hybird turbo. but not sure weter to put it in or not. and there my plans for the moment! any sugestions?
Old 07-01-2007, 13:06
adzs12's Avatar
adzs12 adzs12 is offline
Forum Regular
I had the same problem a long time ago and it was a single wire on one of those connectors under the air filter that had corroded and snapped off, i swapped that part of the loom and bingo
Old 07-01-2007, 14:44
datdrift's Avatar
datdrift datdrift is offline
if your drifting it then steering rack spacers are a must on a s12, as the standard lock on them is shit
what suspension have you got on it?
Old 07-01-2007, 15:48
theres coilovers on it on the front, and cas shocks and springs, camber plates
and up rated roll bars and wish bones. shes prety stiff. tell me more about this steerin rack mod?
Old 07-01-2007, 16:14
datdrift's Avatar
just take the tie rod off the rack and put a s13 spacer from driftworks or somewhere (5mm or so) and bolt it back up, you need to adjust the tie rod - rod end by the 5mm to straighten the wheels back up and you should get the tracking re-done, but i havent got around to it yet
heres the thread i did on it - http://www.nissansilvia.co.uk/vbb/sh...light=steering
Old 07-01-2007, 16:28
Ive got the spacers you need, Im not going to use them
Old 07-01-2007, 18:18
sounds good. i have a race track booked out with a mate for thursday. so im gona test her out then. i had her out before, but now ive irond out the kinks.
cant wait.
