Nice nice
!P.S: in your ecu mapping does the 4 or 8 spark plugs system differe or doesn't matter? |
I think I've answered this 5 times now the ECU is different and the pictures you sent me did not have a 28pin eprom present in the ECU.I've never touched an 8 spark s12 |
sorry
Im seriously interested in assembeling all the kit for this, or paying someone else so map my ECU.
Do get all the kit together one bit that is distinctly laking is a rom file/locations file to use with LiveEdit. Then I need an emulator chip for live editing, and a EPROM burner to save the final mappings to. Oh and a load of earthing straps so nothing gets fried. Is there a difference then between the MK1 and MK2 ECUs? or even with the ECU from a CA18ET powered bluebird? |
The mk 1 ecu doesnt have a rev limiter.
The Mk1 is completely different inside
Any one have pics of the inside of a MK1, I have a MK2 one which I will open in due course (once I have sold the bluebird)
I also have a spare bluebird one so I will see if that has the same chips inside. Does anyone happen to know if the ECUs are interchangeable even though they are different? In all honesty am I better off looking at an aftermarket ECU with it being cheaper and more flexible in the long run? |
