Old 12-01-2007, 23:23
Standard timing will be fine and it will run normal unleaded for long distance commuting, If you intend on putting your foot down or are running a modified setup then use super unleaded. Also Shells new v power contains valve lubricant which is good
Old 13-01-2007, 14:12
Paulpen Paulpen is offline
Paulpen is an unknown quantity at this point
Cheers then chaps
