right, ive already got the plastic bits off, ill have a go with a bicycle cable tomorow, any tips on where to start/technique?
i still think im gonna break it
it will break!! me and silviagod tried to get one out in the scrap yard. its very hard going and takes ages and will deffo crack with out propper tools
start it off with somthing with a bent blade like than on an oldschool can opener... the proper tool to break the seal is a cheese cutter like device they're quite cheap.. not sure how much difference it would make though.. good luck
cheese cutter/brake cable idea sounds like a winner tbh, just find a good place to dig out some of the sealant to put the cable through, and cut away
i cant see why this wont work with a little time and take it slow.nice one !!!!
job done
! cut at one of the sides with a stanley blade, then spliced a brake cable, and just used one strand at a time, after a few pulls it starts to smoke and your away..... took at least an hour.now i just have to get the smashed one out of my other silvia and get this one fitted, and im away! well, ive just got to get it running and get a gearbox mount welded up, bleed the brakes, fit the clutch and bleed that, get the exhaust welded back on....and stop the rear brakes sticking on the handbrake and then see what it fails the mot for......+ i need a rad and a new rubber for the manual gearbox mount
Should be ready for the weekend then
