if you got the discs the same size as the s14 ones, but those that take bells, i could get the bells made up. deamon tweaks list them.
If you were to go to the hassle of making bells then get 310mm discs.
what is a bell?
If they are just modified discs a machine shop could remachine the centres to bolt to the S12 hub.
A bell is the blue bit in the centre:
![]() If you do some homework you should be able to get them cheaper all in than what Apex sell them for
This is all too confusing for my little brain!
I just want to hand over a credit card number and have everything I need sent to me to bolt on lol
convert to s13 front hubs and struts and get some of Dan_s14a's 315mm M3 discs and caliper brackets (using s14 calipers) MUCH MUCH cheaper than the 310mm bells and rotors route
