Old 25-01-2007, 15:26
Sharas's Avatar
Sharas Sharas is offline
Hm... I have the s13 gearbox (its not in the car yet), but diff the will be staying the same, from my s12, if everything fits ofcourse. (im not sure what exactly is crown wheel and pinion, but from what i found realy fast in google, these gears ar in the diff, so im hoping i wont need to change them)
Old 25-01-2007, 15:31
Yeah they're in the diff.
You need to compare the gearbox ratios not the diff ratios
Old 25-01-2007, 15:39
Sharas's Avatar
Hm... Im a little confused now (the gearbox ratios are also a bit different, thou the 4 gear is the same), but dosent the final drive ration depend on the diff? (so if compared to an s13 i should have shorter gear ratios, since the final drive is different).
Or am i totaly wrong here now
Old 25-01-2007, 15:43
No if you want to compare it to an S13 its fine, but I though wanted to see what the effect of using an S13 gearbox would be in an S12?
Old 25-01-2007, 15:49
Sharas's Avatar
Thought so, thanks for clearing out everything for me .
P.S. Since the gearbox is together with an ca18det engine, it makes more sence to compare the final setup with an s13 (in my opinion).
Old 25-01-2007, 16:00
Yeah thats fairly good reasoning if you ask me
Old 16-06-2007, 17:11
ChEsTeR ChEsTeR is offline
Is this pisble that i have dif ratio 4,3 ???
I chcked my speed with GPS today and at 3000 rmp on 4-th gear it says 80km/h after some calculations it turns out 4,34 mayby im wrong with my math. Weels diameter is 615 mm 195/60/15
