well the planned top secret conversion is now off the books, due to the engine being knacked so going down the easy route.... how much is a fair price to have a DET engine fitted? i wanna do it myself, but time is very short at the moment, and i cant wait around doing bits and bobs here and there!
you can get a recondition engine for about 700 thats what mine cost from api engines. the other problem would be finding someone with enough time to fit and wire one coz i does take a bit of time to install it all........ well it took me months with a few teething problems
i thought the engines were a straight swop? it was just the wirirng that was the problem?
yea it is i had the prob with the wiring
I can do you a complete det wiring loom conversion ready to bolt in including transistors/dropping resistors and wired in relays and post it to you with a diagram for connecting the remaining 5ish wires to earth/ignition feed and battery.
Or i can do the whole conversion for you including all parts. Id need the car dropped off for a while.Either a week for just the wiring or 2/3 weeks for full conversion ( This is becasue i only have about 3 evenings a week spare to work on my own projects at my work. The other evenings i spend with the gf It wold cost a bit though as i wouldnt fit a det engine into your car without a basic rebuild. Best pm me. I could be interested in a part trade with your failed engine project
how much would it cost for you to supply 1 of these looms and how easy r they to swap?
I only have the parts to make 1 loom up at the moment im afraid. I dont want to do this for making money really so It would depend on if you were after the ecu,dropping resistor and power transistor and coil packs as there the most expensive parts.
