i may soon be forced to break my S12, as nobody seems to want to take on a damaged one (which i can kind of understand), so if anyone is after any bits (i am also guaging interest on peoples needs for parts) then let me know
the car is standard but for a k&n air filter and the bits of most interest will probably be a set of mint wings in red a rust free tailgate (possibly with a fibreglass standard spoiler, if not then an absolutely mint foam spoiler) 5 extra standard alloys, including 1 that has never been used the shell itself is almost completly rust free if anyone is interested in buying it as it is then im after £350 with everything included, with id say about £150-£200 more needing to be spent on fixing it, otherwise ill break it. let me know if youre interested:thumbs:
if you break mate, could you check out a right hand lower control arm for me, i need a solid one with no ovaling on the link pin hole ,cheers.
i would put first dibs on the front wings if they are mint as you say, gimme a fair price via PM, ill find the money, i really dont want to have to patch up mine, as sooner or later they will rust again.
*also what mk is it 1 or 2 as i need a MK1 passenger door too. (first dibs there too) your only about and hour and half away from me. Cheers.
i'am to far up, but if anyone need doors, i have 4 good ones 2xmk2 and 2xmk1, i'll have to ask if japster wants the mk2's first though.
as an update to this situation, i think i am going to partially change my mind, and do a top secret project instead.
as part of the project i wont be requiring the following bits - rear hatch most of the interior the spare wheel (space saver) 5 alloys with varying tread levels on the tyres there will probably be other bits that i dont need as i go along i will probably need the upper radiator support panel that goesall the way across the top that the lights bolt into, and also a left hand side bit that sits behind the light Rob
ignore my PM back then m8.
good luck with the project.
Cool, good to hear you are keeping the car.
But if the interior is going, what colour is it? Mines the blue and I could do with a few bits, i.e. drivers air vent, and door cards :P I might also be interested in the space saver I recon to give back a little boot but thats heavy to post
