Old 01-02-2007, 23:19
wacomuk's Avatar
wacomuk wacomuk is offline
you could use a throttle position sensor from a 200sx as its potentiometer
you would need some sort of crank sensor (toothed wheel off the bottom pulley?)
does the megga squirt use coil packs? if not some modding of the dizzy would have to be done
does the MS use the MAS sensor or MAP sensor? surly the MAP sensor is the way to go
cant see why it wouldn't work
