#21
finally got Den's prop off yesterday evening.
Did it just in time before the snow hit. He did say he would take some photo's and shove em on the thread, Not sure about a replacement UJ because the prop is a modified S12 item. Gearbox is an S14 and the Diff is a 300ZX so who knows? |
#22
Yep - Took some piccies - Will have to show Pukka, but the one end of the broken UJ is welded to the rear section of the shaft, and it's snapped the inner bit - The photos'll show it better than I can explain! If the inside bits can be took out, then I guess it can just be replaced, otherwise i might be needing to send it back to the guys to get it repaired - Again, the piccies'll give us all a better idea!
Only 450+ BHP from a 1.8? (Well, until I can run big boost again ) - Still, back on the road and looking for victims - Muhaahaahaaa!.... ![]() Yep - I fookin' love me beast ... |
#23
A decent custom prop should have a groove and circlip type fitting,see if you can get this next time .Send it away to get repaired and 4ward me the bill.
. Dont go through Norris though as he may just shove a handling charge on topWhat a pain.
![]() Quote:
