Old 14-02-2007, 14:09
It will be identical to a bluebird one
Old 14-02-2007, 17:26
if you post up the number on the black box on the AFM, it should give the answer in FAST years an models the AFM is from.
i have FAST so if you post it up, ill look it up for you.
i think its a long number with a dash in the middle.
Old 14-02-2007, 23:41
124's Avatar
124 124 is offline
124 is an unknown quantity at this point
I have a copy of the emerald ecu software and am currently learning how to map the thing and also have access to a rolling road at the moment.
Old 15-02-2007, 08:34
Are you running Emerald then?
Emerald system is the easiest to get to grips with. Dave Walker doesn't mind sharing knowledge, so you'll learn alot from his website.
Have a look at the Omex and DTA systems and compare how they do things differently
Old 15-02-2007, 08:56
i have half a dozen different emerald maps running various specs for my engine if they will help anyone.
Old 15-02-2007, 09:25
124's Avatar
124 124 is offline
No I am not running an emerald ecu on my car. I am currently doing a degree and part of the course is learning how to map ecu's and how to tune them on the rolling road. I think Dave Walker is coming into see us as well because we are mapping up some emeralds and installing them on various engines. Kind of like a little compettition between students. If anyone needs anything then I have a lot of very knowledgable people around to solve tricky problems and it would be free help was what I was getting at.
Old 15-02-2007, 09:28
I've already got a wideband gauge, but see if you can 'acquire' some of them
