Old 21-02-2007, 13:59
RichardK's Avatar
RichardK RichardK is offline
Forum Administrator
Cool mate!
Here's a pic of the middle rear ones from Earl's:
Old 21-02-2007, 14:15
datdrift's Avatar
datdrift datdrift is offline
you can get the goodridge ones on ebay for around £50 posted - http://cgi.ebay.co.uk/GOODRIDGE-BRAK...QQcmdZViewItem
just have to search under sylvia
i was going to get a set, not too sure if i should if they are a bit short on the front, as ive got a bit more steering lock than standard?
Old 21-02-2007, 14:31
i had the earls ones, but i had them made about 2 inch longer on the front.
Old 21-02-2007, 14:56
Good find! You'd probably have trouble with them on your setup but they are ok on a Standard road car.
Old 21-02-2007, 18:31
alundra alundra is offline
I have this kit no problem, except that it's 2 pairs; where can order the pair of middle rear, please? Because I have DOT 5.1 brake fluid and i think that i need to change them.
Cheers.
Old 21-02-2007, 18:39
if you have the Goodridge kit then you don't need the middle line on the rear as it replaces everything from the copper brake line to the caliper. You just have to secure it to the car or it might end up in your rear suspension!
Old 21-02-2007, 20:14
my earls kit replace the complete rear as well.
Old 21-02-2007, 20:54
I'll post some pics perhaps i've done a mistake Rear lines in Front, and vice-versa
