Yeh but if they're 15 offset wheels for example they are gonna be damn close as it is.
We need to know the offset
Oh yeah forgot to mention they are 38 offset
yea they are et 45
Well you could probably use up to 25mm spacers. Best see how much clearance you have, as camber will effect the clearance
yea i have a set of h&r hubcentric wheel spacers that bolt on and have 4 studs off them, while i have the rear hubs apart i need to work out if should get longer wheel studs or the same set of spacers as the front>???
I have longer studs on mine.
Very glad I bought these as they have loads of thread where as the standard ones are very short.
