Old 27-02-2007, 20:20
Well you could probably use up to 25mm spacers. Best see how much clearance you have, as camber will effect the clearance
Old 27-02-2007, 23:22
doski's Avatar
doski doski is offline
yea i have a set of h&r hubcentric wheel spacers that bolt on and have 4 studs off them, while i have the rear hubs apart i need to work out if should get longer wheel studs or the same set of spacers as the front>???
Old 28-02-2007, 10:14
RichardK's Avatar
RichardK RichardK is offline
Forum Administrator
I have longer studs on mine.
Very glad I bought these as they have loads of thread where as the standard ones are very short.
