Silvia Engineering did it.
I imagine you'd have to be pretty damn good at tig welding to do it.
tbh, i would fabricate my own plenum, you may as well design a better plenum, it would be not much more to do your own and easier by the look of that, bad welding on there mart, ally weld needs a lot of practice.
I think they just blitzed it with weld to penetrate through to the other side.
Its cast ali as well which will make it harder to weld. You could use a CA20 inlet, and swap the ends over.
