£15 from rally design 40mm ones, ask for uprated rs2000 mounts, then you need to make a oblong plate with 3 holes in, they where mine.
Cheers dude don't sound too hard can you get away with raising the engine slightly & fitting them or do you have to remove the engine, also how did they perform & don't spouse you or Adz have any pic's pf the plate required?
thanks James |
you can fit them with the engine pulled to one side, there were some pics somewhere,
talking of mounts. what the hell are those engine damper kits on ebay all about. they best be very very highly damped or its completely pointless, Im going to make myself one but have it solid with a rose joint on side and a solid exhaust hanger bush the other
. Ive never seen one off the car to feel what those fleabay ones are like. Any info?
s13 Nismo mounts should fit with very minor mods and some DET brackets
They bolt straight on
