Old 18-03-2007, 14:56
yes. Follow the guide if you need too. Its very straight forward once you have everything in front of you.Do all the obvious bits first and you will find that you only have a few wires left and will wonder what all the fuss is about
Old 18-03-2007, 15:14
terry terry is offline
cool , ill be starting the stripdown in 2 weeks or so so will let you know how im getting on
thanks again
Old 18-03-2007, 16:25
There are lots of wires, it depends how you pull the 3 relays section out of the s13. In neils car I had to tie up about 20 spare wires as temporary measure (never know if they were needed at an early stage so didnt cut them). Some of the wires are the same colour to make things harder.
I'll try to get neil to take pics of where I tapped the wires into the original ecu relay and the battery etc.
Old 18-03-2007, 17:27
yup make sure you get the relays with there sockets with wire tails on them from the s13, as per the guide. It makes it alot easier and less time consuming.
Old 18-03-2007, 17:59
Yeah, absolutely lol, be a right ball ache then.
