I dealt with several times and the service and product are very good. I sent him the specs on the OE springs for the MKI/II so you can just say eg 30% uprated -30mm etc.
Ordered my springs today -40mm and 350lb
are these direct fitment springs... 300lbs... front + rear..??
i'll have some.. do they fit kyb shockers... ??? how much, + have you contact details please.. cheers
When I got them they were 25 each spring as long as they are made on a Run of other springs. Otherwise he won't light the fire for just one set. They will fit as standard ones do but you have to be careful when they get over
-25mm. They will then only be held in place on the fronts by the weight of the car and not the strut.
i could do with changing either the springs or shocks on the back, i've noticed that its been jumping a bit over pot holes, when you press each side on the rear, the left side feels softer, i'am using kyb's and avo springs, they are only a year old, something has gone tits up
it was probably down to lumping that Fecking big tubby around in your boot shaun!
sorry to bump and old thread, but i have my shocks now, thanks to kyle, was good to meet you.
im gonna put on new springs with them too, im gonna go for 350lb -25mm will valley springs do these for me shaun??? and if so whats there number m8 please. i could do with a set of Front Tie Rod (strut bar) Bushes to for the front, assuming thats the bar that stops the wheel flapping forwards and backwards?? best place to get them from anyone??? Cheers.
