Old 26-03-2007, 13:39
The actuator should be fed off of the compressor housing of the turbo.
Its probably an average drop for the cheaper type of IC's, but remember that its only a T2 trying to push the air through.
Old 26-03-2007, 13:45
The actuator is fed from the compressor housing but is that where I should also read the boost from?
Old 26-03-2007, 13:51
I see what you mean now...
I think it would make more sense to read it at the inlet manifold. That way you can monitor leaks etc.
Wouldn't turn it past 12psi though...
Old 26-03-2007, 13:53
Good, that's what I thought and have done
Is 12psi the limit of the stock internals or the T2?
Old 26-03-2007, 13:55
Its kind of the limit of the T2.
I found at 12psi with a volvo intercooler that turning up made no difference, and it struggled to hold the boost at the top end anyway (which is the limit).
Old 26-03-2007, 14:01
Cheers, we've got a T25 to fit but it's just finding the time to do it that's a problem, having never done it before we really need two days just in case we cock up!
12psi seems to be lively enough for us for now, if we need to find any more performance then I think we're going to look at weight saving as it improves both (for want of a better word) speed and handling
Old 26-03-2007, 14:06
A T25 is a piss easy conversion, have faith in your ability
