The actuator is fed from the compressor housing but is that where I should also read the boost from?
I see what you mean now...
I think it would make more sense to read it at the inlet manifold. That way you can monitor leaks etc. Wouldn't turn it past 12psi though...
Good, that's what I thought and have done
![]() Is 12psi the limit of the stock internals or the T2?
Its kind of the limit of the T2.
I found at 12psi with a volvo intercooler that turning up made no difference, and it struggled to hold the boost at the top end anyway (which is the limit).
Cheers, we've got a T25 to fit but it's just finding the time to do it that's a problem, having never done it before we really need two days just in case we cock up!
12psi seems to be lively enough for us for now, if we need to find any more performance then I think we're going to look at weight saving as it improves both (for want of a better word) speed and handling
A T25 is a piss easy conversion, have faith in your ability
thanks Obe-Wan but I know how camel handed I can be!! Trust me I make the easiest jobs look hard
