IC pipe work coming along.
![]() chopped the stub off my new shiny IC Gulp ![]() just need the new stub TIGged back on and a plate over the old hole
Looks all good but I bet in hindsight you think it was a bad idea using an external wastegate. Looks like it was a bit of a pain in the rearend to sort especially with the screamer piping.
I like the retro cutting of the IC.
yep total pain in the arse!! i dont want it exhausting under the car or in the engine bay so its turned out to be a pain. i just hope it does spike less and control better than a normal actuator. if it doesnt itll come off as its extra weight and complications. if it does work, thn i may look at rejoining it back to the main exhaust if its too loud or unreliable
Is it adjustable?
as far as i know, but have a boost solenoid valve connected to ecu. with the two tappings on the wastegate, im right in thinking that the one holds the valve shut whilst the other goes to the boost solenoid?
Can't remember to be honest. Sometimes you only used one of the tube's and it depends on the type of controller.
with the profec b, you use 2 parrallel openings on the solenoid with external wastegate, but with an actuator, you use opening on front and one of the sides.
