as far as i know, but have a boost solenoid valve connected to ecu. with the two tappings on the wastegate, im right in thinking that the one holds the valve shut whilst the other goes to the boost solenoid?
Can't remember to be honest. Sometimes you only used one of the tube's and it depends on the type of controller.
with the profec b, you use 2 parrallel openings on the solenoid with external wastegate, but with an actuator, you use opening on front and one of the sides.
not ready to pipe it up yet but will ask you guys advice when id do
cheersjust taken the IC to be welded, should be a few days as they are flat out and i dont want to use someone else i dont know
hi Craig,
Did you do Aintree last year and lend me a mikala jubilee clip, if so do you remember. Fantastic work on the manifold would be interested in the same when i mount the t28 on mine s12, i,m only in Lancs so if your doing local events we should meet up, had a chat with Dave from 3 sisters territory he mentioned that you were working hard on manifold. looks like you have new i/c but an alternative is a nissan gti, its a substancial bit of kit i use one had no problems it seems to have great capacity. To get the most out of the ecu set up might be worth a trip up to Wayne a Rochdale. Hope to see you on sprints this year Fraser. |
I can send that about Wayne he is the pal keep going on about that maps my motor
Hi Fraser, no it wasnt me but ill bet it was Crouchie B (Bryan) in his scimitar SST.
although ive been a regular at aintree over the years (and hold the class record ), i didnt compete there last year and wont be there on the 28th either as the cars still in bits the IC is sorted, just awaiting the welding to alter the outlet. i wanted something brand new really arther than a second hand part so it least i know its perfect and clean. Crouchie lives near Newton Aycliffe iirc, but im in shrewsbury which is miles from you guys, although i do know Dave and have met him at the 3 Sisters circuit before now. as for the ecu, ive heard that wayne knows his stuff, but i use an Emerald ecu so i get the designer of it (Dave Walker, Tech editor for Circuit Driver, Full Throttle, PPC and was the ex Cars and Car Conversions guru too) to do all the mapping. what car do you run on the sprints? an s12? ive seen a couple over the years, one at 3 sisters and the other at Hethel Lotus test track in Norfolk. maybe see you at anitree on 28th
