30PSI speaks the truth.
Mine started clicking on the recent bank holiday friday. * took it off - found it an arse to get to, could probably do it a bit easier now I have located the two bolts. * took it apart (dont take the c clip of the main shaft like i did ) * put it back together after cleaning with WD40 and then luubing with a tiny amount of copper grease. * works fine now cost of new starter saved = £120 or if you go to Halfords £283! |
