Why std plugs are you not looking to tune it??
Spacing on the colder plugs should be set at 0.9mm.
I shall tune it (actually it flamed the other day which gave me the impression it was or at least overfuelling a little). I just want to get it running alright then i'll add the intercooler. I'll know in about 2 weeks whether i'll do it up or not Ive just gotta see what other problems arise.
As Adam suggest .9mm.
If it was standard then 1 to 1.1mm.
thanks for the reply.
Im about to do these plugs tonight along with oil, wiper blade, fuel filter & maybe coolant. Out of interested do you think this car has been abused? everything points to it being that way but it still runs I guess. Rear drivers side brake caliper - needs replacing Gearbox leaking Right rear bush worn Maybe its just me imagining it, still cant believe I picked this beauty up for £70 So if it hasnt been abused its about to be hehe, bring on the drifting!
Mostly everyone at some point has had a rear calliper seize up as thats a pretty common thing as is the rear subframe bushes.
Did you say it sat in a barn for 3 years?
