Get a piper cam in there as well.
cant find one anywhere bud
Piper still do them iirc or alternatively use the Autosprint cam
i will be putting in a s1 uprated clutch to go with my s13 box
Piper still regrind them. You need to send them your old cam.
Some don't recommend the cam, but on my setup it was good. Max power at 6.1K, it was pretty manic at the top end.
The power you could expect would depend on who puts it together and sets it all up. 260hp would be about right on a spot on setup with good fueling but afc isnt the best and it still retains the afm. I expect that you will end up with about 245-250
edit im basing on you using the piper cam as its most beneficial with larger turbos
![]() Quote:
should be good fun then. stripped out sleeper with 250 under my foot
Have you changed the clutch?
