Old 13-06-2007, 19:47
mr_turbo's Avatar
mr_turbo mr_turbo is offline
yer from a pulser. wots a FMIC set up and wot plugs shud i use? soz if im being thick here lol its alredady lowerd n stiffend n i got pilot sports on! i wouldnt mind some nice shocks thou!
also im having problems mounting the actuator has ne 1 done this if so how?????? lol i also need a 200sx s13 boost pipe from the turbo as it is different from the siliva 1 n e ideas ???
Old 13-06-2007, 19:58
fmic=front mounted intercooler
Old 14-06-2007, 10:48
ChEsTeR ChEsTeR is offline
I have recently chcecked haw much the stock injectors can handle. 0.7 bar is a maximum preasure on a T28 turbo with no fuel system upgrade except walbro fuel pump. It leens to 12,5:1 at 6000 rmp. The maf shows 4.95 volts and u cant ad any more fuel.
Old 14-06-2007, 10:54
How did you work that out?
Old 14-06-2007, 11:09
With a wide band o2 sensor ecumster piggyback compter wich tell me AFM imput voltage to the ecu and a boost gauge. And i have a volvo 740 IC.
Old 14-06-2007, 11:27
So if it maxes out at such an early stage how do the S13 owners manage 270bhp @ 1.2 bar?
It is worth noting that higher boost will result in higher fuel pressure so to some extent a reasonable fuel ratio can be maintained.
Old 14-06-2007, 11:35
s13 ovners have 370cc injectors compared to 270cc in the s12's Yesterday i have instaled s13 injectors and remaked the MAF its now 60mm wide not mear stock 45mm. MAF that big will leen out whrew whole ragne of rpm's but will allow me to tune it more precise in the higher boost range.
