Old 15-06-2007, 07:31
ChEsTeR ChEsTeR is offline
I'm preaty shure they have. Because the 4 spark ECU dos not cooperate withe 8 spark MAF
Old 15-06-2007, 07:59
Could explain the higher than expected voltages
Old 15-06-2007, 08:16
so what should i do?
Old 15-06-2007, 08:20
Try to use an S13 afm, but then your work on original afm maybe sufficient
I guess the pin outs on your ecu are different to the UK spec?
Old 15-06-2007, 08:39
The signal cable is the same in both ECU's and the voltage is the same but the 4 spark does not accepsts it dont know why. I will try an s13 one with a lambda.
Old 18-06-2007, 23:44
mr_turbo's Avatar
mr_turbo mr_turbo is offline
got everything now ive made up a now bracket for the actuator i went to ilford tonite to get the boost pipe so hopefully fingers crossed ill have my t28 on 2morrow along with my s13 clutch!
Old 18-06-2007, 23:48
Did you go to Burtons at Gants Hill then?
