Old 15-06-2007, 09:20
Try to use an S13 afm, but then your work on original afm maybe sufficient
I guess the pin outs on your ecu are different to the UK spec?
Old 15-06-2007, 09:39
ChEsTeR ChEsTeR is offline
The signal cable is the same in both ECU's and the voltage is the same but the 4 spark does not accepsts it dont know why. I will try an s13 one with a lambda.
Old 19-06-2007, 00:44
mr_turbo's Avatar
mr_turbo mr_turbo is offline
got everything now ive made up a now bracket for the actuator i went to ilford tonite to get the boost pipe so hopefully fingers crossed ill have my t28 on 2morrow along with my s13 clutch!
Old 19-06-2007, 00:48
Did you go to Burtons at Gants Hill then?
Old 19-06-2007, 23:38
mr_turbo's Avatar
erm nar see a 200sx being broken on ebay so rung him n wemnt get it
Old 26-06-2007, 19:03
mr_turbo's Avatar
its all on now had to mod alot of things to get it on but its on now doesnt spool till 4000rpm which is weird but wen it does gives a nice bang
Old 27-06-2007, 12:52
mr_turbo's Avatar
has anyone else done this upgrade and knw what the safe boost pressure is for this turbo? and what can the engine take safely im runin about 10psi atm with no intercooler and not turning it up until i have intercooler on!does go like stink thou cnt beleive the improvement not jst in feel but by racin other cars which i raced ddays ago with the smaller turbo i pull lenths ahead
