Which preasure plate shoud i use ( wich year there are two) and which preasure bearing? Should i use s12 or s13 and which one??? Im changing the cluch this weekend because mine is sliping during gear change. Last tim it slipet when i changed from 1-st to 2-nd and 6K rmp
i used the clutch from a 1989-1992 200sx turbo n used the pressure plate from it as well! the release bearing also fits obv jst need to press it on deff a gd upgrade thou feels so much faster now
I have bought an excedy disc and NKK preasure plate. I hope that exedy is any good because in my friends s13 it sliped at 280 HP
