Thout you might like to see what i ahve found & planning to use...
A set of Jaguar XJR front dampers designed to cope with there huge engines, there in really good nick & ar bout 60mm shorter than the s12 ones, just waiting around for my lowering springs to see how they will work together.
martin, where was your measurements from??? i measured the s12 one today they measure from the center of the lower bolt hole, to the top of the thread made bout 650mm
![]() ![]() was this the same as where to and from you measured, if pos could you pop up a pic or text me a pic same as i have, i can give you my number, sadly if you see my other post, i now really need it.
I probably took it from the bottom of the shock to be honest. Not sure how much shorter a coilover shock is, but the S12 one is a very similar length to the S13 one anyway
i need at least 50mm smaller than the std s12 shock, im gonna take this std s12 one to local motor parts dealer tomorrow and see what they may be able to match up for me slightly shorter.
Seems a good idea, there are a lot of shocks around that are in the same style.
When I fit my LSD I will remove a coilover and see what its like without the spring etc.
i HAVE to get this sorted by wed as my MOT runs out then, and i need the car, unless you have a std set of springs kicking around till i sort this prob.
I might know someone that may have a set, I'd have to ask him tomorrow
