Old 26-06-2007, 08:14
There's no space for a viscous fan
Old 27-06-2007, 08:22
s12nelly16v's Avatar
s12nelly16v s12nelly16v is offline
s12nelly16v is an unknown quantity at this point
Default thanx !
hi guys thanx for all your interests ! i'd thought about slamin a turbo on but the compression is to high and to get new pistons was gonna cost about £80 each ! owtch , so i'm open for ideas, as for the exhaust, my front pipe seems to be ok ! but the rest is on its way out so if anyones got a staight through pipe 2 1/2 - 3 in through to the rear, i have a 'magnex' back box to hook up to, i also need full suspention as mine has about shot it, anyone knows of a good stiff 'n' low set-up , that would be great ! i know i have alot of ideas but sadly not alot of money , all offers and ideas will be read and contemplated thanx again , Neil
" Rear Wheel Drivers Do It Sideways !"
Old 27-06-2007, 08:53
hi mate, you can run a turbo on std compression, its been done by a couple of guys in aus on fj20.com, and still running after 2 years at 18psi, you could always have a slightly thicker copper gasket on it, i think they saw around 350+ bhp.
Old 27-06-2007, 09:01
cool i was told it would'nt run ! the compresion of 10:1 was to high and it would blow the engine even if driven like a old lady ! i have a turbo would it take much to fit !?!
