other than pedal box and clutch slave cylinder, can you think what else i'll need to convert to manual, apart from the obvious, gearbox
auto box has a different size(bigger) crossmember, so you will have to fabricate one, also the prop is a different size.
pedal box is a bastard to fit/remove......enjoy Last edited by datdrift; 29-01-2006 at 19:57. |
is that all then mate, its having an rb25 gearbox in anyway, so i'll have to fabricate something.
(ii)I think there is a like a coller you have to remove so you can mount a flywheel instead of a flex plate but i may be getting confused with the v6 I put in my s12
Shaun
Have a search on sxoc as a few of us rambled about this...
i'am not using the caet engine thats in, i'am using a manual fj20.
i'll do a search on the sxoc.
