det ones are not barbed, they are o ring and measure 10mm, the et ones fit 8mm hose.
Ah.... so when everyone says "fit DET injectors, they are 370cc" they actually mean.... "fit DET injectors AFTER you have made a fuel rail"!
So do you know if there are any direct replacement 370cc injectors that will fit directly into the ET manifold and have a barbed fitting at the top? Or is making a fuel rail my next project????? Or am I going to have to be a hero and rodger an 8mm fuel hose onto a 10mm injector with hose clamps and hope for the best! I mean... petrol, it's not that flammible it it leaks right??!!! ![]() Conkers.
Website: http://www.racing-green.com Blog (with 180zx build pictures) http://racing-green.blogspot.com/ |
Don't you have to do both? I've got the injectors but I've not done anything with them yet
i had a rail made
Should be able to squeeze the fuel pipe over the 10mm end. I would be tempted to flare the fuel rail ends up a bit and use a 10mm pipe. All a question of whether it will leak though when the highest fuel pressue will be on a tonk at 20psi boost, which is approx 55psi fuel pressure.
so rodgering will be the order of the day....
Any ideas about how to hold the injectors in the manifold.... orig. injectors use two 5mm threaded bolts and a clamp to hold them down.... will have to fabricate something for that too I suppose. A the end of the day, nne of this is too much hassle, but it sucks that I for some reason believed that the DET injectors were a direct replacement... even if in reality the extra modifications might turn a 1hr fiddly job into a 3hr fiddly job.... Pictures when I am done........... Conkers
you can take the rubber pipe off the standard injectors and force it over the s13 injectors. have done this, i think gripos rail is the same
