Thanks! I'll check the boost before intercooler.
In case of a MBC, must i set in 3rd gear the desired 12psi, despite of spike in 2nd gear?
the best way to check your boost is in 4th gear. If its dropping off i would say your actuator is probally week.
or you have a boost leak, before i got my intercooler setup, i had a small leak in the orange gasket thingy, that did the same, 1st and 2nd wasnt really noticable as you go through them to quick, but 3rd and 4th was very noticable as thats when you stay in it for a longer time.
i would check yer pipes and anything else between the turbo and the inlet.
The orange thing was replace by this:
when i fitted my intercooler set up, i knew it was prone to break.Tomorrow i'll set the desire boost in 4th gear, will know if in 2nd the boost is stable. P.S: i checked the timing it's at 15°, warm condition. Are you agree that in same rpm, i'll get the same amount of boost +/- 1psi?
i knew you had taken off the orange thingy, i was using that as example coz mine did leak, with same effects, when you say boost drops, how far does it drop, also what type of boost controller do you have, if its bleed, it will spike then drop. if you make it run std boost, i.e put the std pipe from the turbo housing to the actuator, do you still get drop???
boost on a t2 is always going to drop off at higher RPM, the exhaust housing is tiny, the T25 does the same thing exactly on the DET
Some news.Seems I was afraid for my car because if just turn the screw for just an amount to only feel more torque and let it as it is. I explain, I've turn 3 times (in 1/4 turn step each) the screw now in all gears i've constant 0.6 bars, no drop and a few spike at 1.0 bars. I'm very happy! What a car! When i turn 1/4 turn more, I have the same boost except that the spike goes up to 1b (like 1.1, i mean the needle goes pass the 1b mark on gauge), seems the limit of this MBC (it was sold to maintain 1 bar... but for 15$...). Thanks for all support seems the next tape will be an electronic devices but really expensive even old ones... ![]() P.S: I love more my S12, what about you? |
