Old 14-08-2007, 09:21
badboy's Avatar
badboy badboy is offline
badboy is an unknown quantity at this point
if the diameter is the same could i not use my flange
Old 14-08-2007, 09:22
Turbo end or exhaust end?
Old 14-08-2007, 09:23
badboy's Avatar
turbo end, basicaly i would like to fit a larger bore down pipe
Old 14-08-2007, 09:37
If you mean swapping the T2 flange onto a T25 S13 downpipe then wouldn't it be easier to just go for the T25 conversion and possibly even buy a buy a SS downpipe?
I can't see it causing any problems so long as you're handy with a welder. I didn't think that there was that much difference between the two though?
Old 14-08-2007, 09:55
badboy's Avatar
dont realy want to convert to t25 just a bigger bore, might have to knock something up myself just wondered if there was an easy way round it, ta for the advice anyway
