i had a ca18et engine from a silvia and tried to put it in my ca18et bluebird(fwd) and only about 3 of the gearbox bolts lined up
if the worst comes to the worst i could always get a bell housing adapter made up , but i'm gonna try and cram in all the 4wd stuff in there if i can, at the moment i'm just exploring all of my different options
The SR20 will only fit in a car with the original drive configuration that it came out of due to engine mounts and gearbox. A GTI R eninge will not go in a Primera even though they are both transverse mounted because of the 4 wheel drive transfer box and gearbox, and the engine mounts are different on both from the rear wheel drive SR20.
sounds like some major silvia surgery comeing up then
But you will have a job putting a RWD box onto an transverse engine, incompatible. Why not try and get an S14 engine instead? easy to get hold of. |
iv'e already got the pulsar running gear (from my last car) i'm just trying to sound out people as to weather a pulsar lump would go on an s14 gearbox, but i'm still gonna try the 4wd route, its going pretty slowly at the moment coz i can,t spend much time outside in the sun coz i'm having chemotherapy, so i've bought a gazebo to cover the front of the pulsar while i strip it, and i still haven,t found an s12 yet , cash is waiting
