Old 23-08-2007, 19:09
323ian 323ian is offline
Thanks mate.
Old 10-11-2010, 18:03
mr.bishi mr.bishi is offline
mr.bishi is an unknown quantity at this point
Hey all.....sorry for the threadromancy,but i have a quick timing related question.
I picked up an s12 auto at the weekend and it was having running problems....not helped by the dizzy being loose!
Obviously,i need to set the timing,so....Is it set using no1 or no4 on firing stroke? I've had a look in the manual,but it didn't seem to say...
Cheers..
Old 10-11-2010, 19:08
You'd typically use no.1 but 4 will do the same
Old 10-11-2010, 20:13
Actually,that has just dawned on me that it's the same thing.....The reason i ask is,i cannot see my timing mark under the strobe using no1 but i can using no4 and it's vexed me a little. The strobe is flashing too
Unless it was picking up a signal from another lead i guess....
Thanks anyway.
Old 10-11-2010, 20:48
alundra alundra is offline
Check resistance of each wire.
Old 11-11-2010, 13:53
What value am i looking for? 30k rings a bell?
Old 15-11-2010, 14:25
This gets stranger......my mistake on this,but the timing marks are actually lining up on 2 and 3 firing,it was 3 i was using,not 4. That's why i can't see it on 1.
Is there anyway the crank pulley can be put on 180 degrees out? Usually they just have one keyway?
I can't get my head around how else this can happen and the engine still run??
