Other than a locating tab on the driver side bush they're otherwise the same.
Obviously I will check that they will work (I have an S13 rack and subframe to compare)
Not sure I really need them, but I'm happy to make up the numbers!
the bushes on the rack that i took off of my mk1 are different in the way that one is in 2 halves and the bracket is more pointed and the other bush is in a recess and in 1 piece.
i would have said they look the same as the s13 kit with lhs and rhs?
If they are different then that counts me out.
Well I'll leave it until I check whether both are the same size or not. Maybe the driver side one is slightly larger on the PAS rack?
i'll go and check for you in a min.
