[quote=graememk;20351]hiya as you may or may not know i have a s12 in a mk indy kit car[quote]
i knew if you boost you will need a intercooler!!!! i think the max bhp is reached at 5600rpm (on standard turbo & ECU) you may get it higher with the megga squirt setup max boost (with an intercooler) on standard internals is 13psi (should put out 185/200bhp) you can run 17.5 deg BTDC as standard, this gives better off boost performance.
