Old 10-09-2007, 23:14
are the r33 ones any longer?? are you using the s13 suspension set up?
Old 10-09-2007, 23:20
They're probably a very similar length. The reason I got them was coz the rods on the doner S13 I had were pretty shite.
Yep I have the S13 hubs on the front. When trying to use standard rods with them they had to be adjusted longer. But they're probably not safe as they're close to the end of the travel. However when i fitted the new rods they were about 1.5" too long.
I wouldn't worry about using S13 ones, try to get the S12 rod ends. The rods are only a few inches long, compared to like 9" or something for the S13 ones, so they're techincally stronger. Dunno why Nissan used short rod ends/long rods for the S13 compared to short rods/long ends for the S12
My above findings are on my Datsun which has a different rack and different track width to the S12, so you may find things a little bit different. I know some people have fitted S13 hubs over in Oz so try their site for more info with the rods.
Old 02-10-2007, 16:32
on that japarts site, what part number was what side, they do specify LH and RH, but was unsure if they were right, assume LH and RH are as from sitting in the car LH being passenger side etc, can anyone clarify this for me. cheers.
Old 02-10-2007, 17:03
LH side is passenger side but they are no longer able to get them, they can only get driver side
Old 02-10-2007, 17:40
I think its the drivers side one he needs
Old 02-10-2007, 20:05
tis the drivers one i need. cheers
