Struggling to see which one your holding to be honest, but it might the temperature gauge wire
If it is where does it plug into as I have looked but not found anything that looks like it would plug in to.
Its to the right of the yellow plug as pictured
Cheers I'll take a look next time I'm with the car.
it looks a bit to big for the temp gauge, unless its the photo, temp gauge is the a small spade connector on mine, well it was on the blue mk1, but that din't have a cover over it, i'll look at mine in the morning.
I have been looking for a spade connector to plug into it as it is of that size.
that will be the one that 30psi mentioned then, its on the left side of the thermostat housing, tooked away.
i agree with 30psi, it does look like the temp gauge wire, its located behind that rad pipe you can see in the pic
but whle that is unplugged does you dash temp gauge work??? coz if it does, then its not the temp gauge wire (obviously ) then it may just be a spare, as im sure i dont have any other spade connectors on mine in that area.ill have a look on the spare head i have and take a pic if its still on there. **EDIT**
Cheers being tucked away there is most probably the reason I've not seen it.
