Old 01-10-2007, 12:29
from std or from last season?
Well in general from a standard car. Also be interesting to know what the geometry is too
Old 01-10-2007, 12:39
from std its got shorter AVO coilovers with adj spring platforms on the rear with uprated springs (std car has coilovers but not adj or adj platforms). its semi'trailing arm suspension which has to be retained due to the regs (cant change to dbl wishbone etc) but its rosejointed for toe adj. Rear disc conversion using wilwood calipers and pads (not needed previosly, drums were fine upto 250bhp). rera roll bar adjsuatbel with rosejoint droplinks.
front end has rosejointed lower arms and polybushed uppers. std car has springs between the wishbones but pushrod dampers, so ive stregthened upper wishbones and fitted coilver springs and dumped the springs between the wishbones. front dampers are trick AVO dbl adjusted with custom valving.
car runs approx 2.5 deg camber and zero toe. thicker anti roll bar with rosejoint drop links.
front brakes are large-ish grooved AP race discs with AP 4 pot mega light ally calipers and choice of Mintex or Pagid carbon metallic pads.
most of our guys that run in teh lower Modified class run stiffer springs front and rear and AVO or spax dampers and the cars are really good on road tyres. mines had to have more done because its not a compromise (super mod class), doesnt get run on the road.
Old 01-10-2007, 12:45
Cheers craig, thats cool that it has double wishbone up front as standard. Do the rose joints make it much noisier/harsher?
Why have you opted for zero toe?
Old 01-10-2007, 13:50
yeah dbl wishbone setup at the front, actually vauxhall chevette. Good ol scimitar factory parts bin car design lol.
rose joints do make it harsher, i dont think id ever use them on a road car suspension. wear rate and dirt ingress gets to bad for a road car. I like polybushes for road cars, firmer without removing your fillings and still hugely better location the rubber bushes-Yuk!
Scims have zero toe as std, but to be honest ive tried toe in and toe out. toe out gives better turn-in but makes inner tyre shoulders overheat as they are really running too much negative camber when you add the dynamic camber in (camber change thru suspension compression). it also makes the car wander a little at high speed too, but not a major issue.
car runs better .5 and 1 deg of rear toe in too to make the car stable.
