I had a similar problem and it turned out my leads were shagged.
New ones from Nissan (£58) but worked a treat. Strangely, Halfrauds list them at £39 a set, but say that they have no supplier to order them from ![]() I also found the air filter to be upside-down, so christ knows how much shit got in there. |
My new HT leads cost £12.50 from a friendly motor factors, but I'm still having this problem. Well it was missing on boost, so got cooler plugs and it was fine on boost but now misses below 2K rpm.
new quality leads going on soon! |
i think magnacor list them for the s12.
All my stuff just been delivered to work from Nissan
so tomorrow i'll have them all fitted, fingers crossed!The leads were £45 for genuine nissan ones |
All the bits fitted an seems to be running better but still not 100%. Found the bleed valve couldn't be adjusted as its seized so chucked that. Went for a blast to Ikea with the misses an seems to run smoother (but slower!!) and temperatures good now but still a bit lumpy? Oh well its better than it was so thanks for help!
I would still check the idle CO hasn't been set too lean to pass the mot as this made my idle very lumpy and the car jerky to drive, also incorrect valve clearances made my car run rougly so meet be worth checking
Just got a cold start thing (air regulator) second hand off ebay. fitted it and now it idles at the right speed from cold
Still bit lumpy upto 2000rpm so goin into mates garage to use the CO machine next week when i'm off work- let you know how it goes!
