Old 09-10-2007, 22:26
323ian 323ian is offline
Thanks for your help, only way i can think of doing this effectively is to drop the subframe down a bit and get some heat on the casing to help make it a bit easier to fit them, i have already got a set of stock bushes to go back in.
Old 09-10-2007, 22:58
smoker's Avatar
smoker smoker is offline
I dropped my subframe as low as i could on the bolts and used a chisel between the subframe mount hole and the outer part of the bush to get the old bush out. To push in the new bush i used a long bolt and two 1/4 inch plates to pull in the bush. Might not be the correct method but it worked
Old 09-10-2007, 23:01
Thanks for that mate, thats a very good idea which i think i will try.
