Old 20-10-2007, 16:30
head looks fine no signs of corrosion or anything, i guess it could have a little warp in it, but would be coincidence that both my heads have blown the same place.
i can understand that with your FJ tbh, its gonna be under a hell of a lot of stress.
my ET running bout 10psi isnt really straining the gasket, thats std boost on the DET.
wheres the best place to price up an ET copper gasket.
Old 20-10-2007, 16:45
you can use the det steel one, it just needs a slight mod on it, if you go for copper, speak to mike tanski @ ferriday engineering, i ran 32psi on the ca18et and it stayed in 1 piece.
Old 20-10-2007, 18:56
dont you need to have both surfaces skimmed for the use of a copper one??? or dont it make much difference to a normal one, just they hold the high compression better??
that pic is of the one that blew, hhmmm clearly
Old 21-10-2007, 11:15
old-and-rusty's Avatar
Looks like it may be a common problem on ca18et`s.
When I first got my s12 (many years ago), the head gasket had blown in exactly the same place .
Regards,
Ian.
Old 21-10-2007, 12:47
No.3 runs the hottest out of the cylinders so is most likely to be the one that kills the head gasket or the cylinder to get the most detonation damage
Old 21-10-2007, 13:18
yeah,i think you need to have the block and head skimmed to use a copper gasket.
