where can i get a braided oil line for the turbo,?
hose solutions can make up custom braided lines and are cheeper than buying goodridge ones
i have had braided brake lines, turbo oil line and turbo water lines and a braided line for the oil pressure senser from them so far and they are all good
if its an early engine (feed from inlet side of block) you'll need to get a custom one made up. if its a late engine (feed from turbo side of the block) just use an s13 one
You'd be best to use the S13 piece that goes in the block too if you want to use an S13 line as you will find it rather tight otherwise.
veyr true, thought of that while i was out after i posted
Thanks guys. But whats ther bit i need for the fit?
