Old 01-11-2007, 22:06
old-and-rusty's Avatar
Originally Posted by docertabum View Post
I did it... the pressure of fuel was 2.7-2.8kPa in idle situation... normally it should be somewhere around 2kPa I think....
For the FJ engine fuel pressure check, the s12 manual states:
at idle approx 206 kPa (or 2.06 bar or 2.1 kg/cm2 or 30 psi)
the moment throttle pedal is fully depressed approx 255 kPa (or 2.55 bar or 2.6 kg/cm2 or 37 psi).
Hope that gives you enough different pressures to go for ....LOL....
Regards,
Ian.
