Old 07-11-2007, 17:24
Originally Posted by umpkin View Post
just get that and put your pully on it, and you have to mess with the wires slightly. i have a mk2 one on my mk1, just changed the poly V to a single, the mk2 has 2 spade terminals as opposed to the nut and studs on the mk1
when i tried using the mk2 alternator with the mk1 pulley the hole in the pully is bigger, i had to have a piece machined and pressed in, then it is'nr quite inline with the other pulleys, it sits a few mill back and wears the belt after a bit.
Old 07-11-2007, 23:36
i dont have the pully nomore no sorry
i never found any prob with the shaft size everything fitted fine.
if you have the spindle and the nut turning seperatly to the pully, means you have prolly cracked the seal on the pully, but have jammed the nut on the thread in the process.
cant remember if it was a left hand thread on the nut either??? prolly not...
Old 08-11-2007, 07:51
It's a right nightmare at the moment, spent about 40minutes in a motor factors trying to find one that fits, the replacement it lists for mine have single vee's, and some list multi vee but only in 60amp, while mine was 70amp.
I will have another go tonight, I have found one that ticks all the boxes but thats £200!
Umpkin where did you get you mk2 one from and how much was it??
Old 08-11-2007, 17:26
i got it off the side of and engine i got from a scrappy :P that is now in my car, although my engine is a mk1 it had the polly v pullies on it, but when i did the swap i was in a hurry so i changed the polly for a single rather than the rest to polly
Old 08-11-2007, 23:12
mr_turbo's Avatar
mr_turbo mr_turbo is offline
i know a few people at unipart i gave them a ring they sent mine off to be recond got it back in 2 days cost me £90
Old 08-11-2007, 23:48
zxocmars zxocmars is offline
I've got a selection of alternators at my workshop but haven't a clue what they are for.
I'll check part numbers and see if I have one that you need if you like?
Old 08-11-2007, 23:54
mr_turbo's Avatar
i also have a few but not sure what condition there in
Old 09-11-2007, 07:45
Got one ordered now as I was sick of the Silvia just sat there . . . . but they've rung back and told me it's going to take 10-14days as it's coming from Denmark
Off to bag up some axle stands and a jack and strip the suspension down, rebuild the fronts and get the new springs on, then it isn't a total waste of time.
