mines spoils aroiund 3000-3500 bit laggy at times but worth the punch all day long just need it rebuilt and not going to pay out for it to be the same as it is might aswell increase the power slighty
![]() ![]() HYBRID it is then!!!! |
3500 rpm is a bit laggy for a T2 (which I assume you're using?). My T3 was 4,000rpm.
I have a nice turbo here which I need to get round to fitting. Its a T28 from a pulsar with a T3 compressor housing.
mines a T28 form a pulsar hents y its 220bhp i cant get any more fuel in atm so stuck at 11psi
Was gonna say thats pretty laggy otherwise lol. I was ok with fuelling on my T3 up to a bar but I used a adjustable fuel pressure reg. I got 215bhp at the wheels with that
on standard injectors?? and pump?? ir not what was you using?
i turned my boost up about a month ago to 13psi and at the top of 2nd and in 3rd and 4th under full throttle it kept cutting power asif it couldnt fuel right! turned it back down and it was fine! |
What plug gaps are you running? And what plugs?
I was using a walrbo but only as a safety measure. Not sure when the S12 pump runs out of puff. Std injectors and all that yeah.
im using 7's with a .9 gap i think!!
hmm im puzzled now want more power |
