The ABS light has come on the trusty Nissan diesel, does anyone know if they have a fault reader built in or some way of telling whats wrong with out getting slapped at a garage? the MOT is up early Jan so need to get it fixed
its a w11 1999 8v diesel
does the brake pedal judder sometimes like the abs is kicking in for no reason?
i've had a few primera's with cracked abs rings on the cv joint! if it is that then that'd be the symptom!
take the bulb out for mot till you sort it
if abs is fitted the light has to work! otherwise it'll still fail
i had a gt earlier in the year, mine had same thing turned out the sensor had got coverd in shit so scrubbed it off and it was fine......
I hate primera's and every owner so far. Not including you
remove and clean the sensors and wire brush the trigger wheels
